D180 and Kavlico
Hotscam
I replaced the old VDO fuel press sender by a Kavlico.
Updated the firmware to 5.6.1 which is supposed to have 6 choices of pressure sensors including Kavlico.
After the update I still don’t get more than 3 and not the Kavlico.
The EFIS reads v 6.5.1 when I check.
Inunderstand EMS firmware is automaticcaly updated with EFIS upload, but EMS does appear non updated.
What am I misding ?
Jack
That sounds like it should work. Can you recount here the menu traversal you're using to get to the setting?
Hotscam
Solved the problem.
Reloaded the support package from the Dynon site and downloaded the D180 again.
Works !!
Strange problem as in both cases the version of the 180 read 5.6.1
Dropped a bit somewhere.
Thanks for your help
