JohnH
I installed a D180 in an RV6 about 2 years ago using the Dynon supplied wiring harness. I am in the process of adding GPS (Garmin 296) and serial output for a Garmin 327 transponders. I tried to update the firmware and could not get my PC to communicate with the unit. I have done this successfully on 2 other Dynon EFIS installations, so this is not a first time for me.
The sserial cable with a D9 plug is connected to the 37 pin EMS plug in the D180, the manual says that this port is only for EMS logging. The manual also indicates that the PC connection normally occurs with the serial port on the 25 pin EFIS plug. Should I connect a new D9 plug to the 25 pin EFIS plug and then try to do the firmware update or should it work through the 37 pin EMS plug?
