D180 showing a left turn in level flight
MikeMcD
Hi,
My D180 is having a couple of problems. Its showing a left turn in level and when on the ground. The airspeed is also not agreeing with the analog airspeed indicator in the airplane. Any suggestions would be greatly appreciated.
Thanks, Mike
Mike McDonnell
2007 CubCrafters Sport Cub
On the airspeed issue, how much is it off? You can perform a zero airspeed calibration if it's wrong at lower airspeeds.
Assuming you mean turn rate is showing a left turn, it should clear itself our after a period of straight and level flight. If it doesn't, contact our support team (contact info in sig). If you mean it's actually leaning left, you'll probably need to contact our support team for further help.
MikeMcD
Thanks for the reply...it's leaning left. I will contact the support team.
