I have a D180 installed in a Vans RV-12. It has worked fine since installation (airplane has 40 hours on the Hobbs and has been flying a year). Today, I went to turn it on and the blue start-up screen came up as usual but then it shut back down. This was using the internal battery. I then tried it with the airplane's avionics power instead. It brought up the blue start-up screen, went black and then brought up the blue start-up screen again. It continued to cycle like this without ever getting to normal operation. I started the aircraft and again tried to start the Dynon with the engine running but still had the same problem. I last flew the plane a few weeks ago. The only issue I have ever had in the past was the D-180 shutting down shortly after starting the airplane. However, upon restarting, it was always fine and this has only happened a few times.
Thanks for any advice. Hate to remove and send it in!
