Dangerous software error. The autopilot switches off during flight!
Mike Linckels
Luxembourg
Please, Dynon team, fix this immediately.
This error is a good reason for customers to choose an alternative product.
It took me a long time to identify the error and during that time I completely lost confidence in the system, especially when the AP switched off during MVFR flights.
Description of the problem:
During flight, at any given moment, the message ‘Autopilot disconnect’ appears and the AP switches itself of . It is possible to switch it back on. Sometimes it stays on for the rest of the flight, but sometimes it switches off again after a few seconds. During the switch-off, I could sometimes see a red ‘X’ on the side of the PFI for a fraction of a second.
I connected a camera via the USB module and noticed that the problem only occurs when I display the camera image on the HDX. Even if it disappears again after the first display and the map is shown instead, for example, the problem still reappears. Even, when the camera is disconnected from the power bus, the problem still reappears. So, for the error to occur, it is sufficient to display the camera image just once briefly.
The camera image has a very low refresh rate and is sometimes distorted (horizontal line errors).
So far, the error has never occurred when the camera was not displayed and still connected and powered.
My amateur diagnosis:
I think that the camera is sending too much information to the HDX processor and overloading it, so that it briefly stops receiving information from the ADAHRS module and then switches off the AP due to not getting position information.
Or, if the problem only occurs on my system, it could be a memory problem, but I have heard from another user with the same problem.
I trust the Dynon team and hope for a quick update.
Kind regards,
Mike
vlittle
Mike, you should check your datalogs. The AP dropping off line can be caused by more than one problem, such as loss of gps signal, an intermittent autopilot button or even a flakey power connection.
Dynon will probably be able to help when you submit a diagnostics file.
Years ago, I had a Trutrack autopilot that would drop offline without warning. Turned out that the extended GPS sentences it was receiving would cause an internal timeout. Working with Trutrack, we indentified a workaround, and a follow on software upgrade to fix this problem.
The key here is 'working with’. Good luck.
Mike Linckels
Luxembourg
Hi Vlittle,
thanks for replying,
AP only turns off when Camera is displayed. No Harware issue!
Mike
Stevec
Have you discussed this with Dynon? You make no mention of it in you post. They do not monitor this forum continuously so you should contact them directly with your problem.
sebasti007
Hello Mike, really happy to hear this from you, although it is absolutely unacceptable and worse.
I have ab the same problem with my HDX while switching to the camera image, AP off after some time and red cross for a milli second.
I have addressed this since more than 2,5 years to Dynon, they were aware of that problem, changed something with the SW update, then deleted in one version 2 years ago the opportunity to activate the camera and than came out with one of the latest versions, that should have fixed it. I was always in regular contact with Don J. from Dynon team. I switched and changed so many things, got a new video adapter….nothing changed and the gave up the support for me and told me, that I am the only one now with this continuing problem!! So I accepted that and never used the camera again unfortunately!
So I am still interested in finding a solution
best regards from Berlin
Sebastian
