Data acquisition
dbl39
Does the dynon skyview have the capability to log data and have a playback feature showing at least attitude, altitude, and speed.
Log data, yes.
To set the resolution of the log file, SETUP MENU > SYSTEM SETUP > DATA LOG SETUP.
To export the log file, SETUP MENU > SYSTEM SOFTWARE > EXPORT USER DATA LOGS.
SkyView does not have the ability to "replay" the data logs on the SkyView display.
There are a few PC apps that can read the data though, like Savvy Analysis, and GPS visualizer, to show the data from a flight on a graph or map.
dbl39
Thanks, will it output all the data it receives from sensors and adahrs?
dbl39
Two clarify what I am looking for. Will the skyview log flight data information such as altitude, airspeed, v/s, g-load, attitude? Not really interested in engine or position data.
n456ts
Do not write below this line
Attached a photo of an example of the spread sheet.
dbl39
Thanks. That seems to be just what I would like albeit in tabular form. I know the data acquisition systems in race cars had software that could actually draw out the track shape just from the sensor readings. Do you find the readings to be accurate in values and time? I would be more interested in airspeed and baro altitude than GPS information
