Jamal haider
- Joined
- Jul 27, 2020
- Messages
- 6
We are facing a problem of delay in fuel flow indication with increase in RPM or percentage power. We havel Lycoming engine IO-540 with Skyview suite.
The problem is that during operation, whenever the throttle is advanced or retarded the fuel flow increases, but it takes approximately 10-12 seconds to reach the desired value.
I am attaching a picture for understanding. In the picture you can observe that RPM rise from 2000 to 2600 in 5 secs whereas the FF takes almost 12-14 secs to stabilize. The same issue is encountered once the throttle is retarded. The fuel flow sensor I use is FT-60 Red Cube and it is installed as recommended by the OEM.
Any help in this regard would be highly appreciated.
