Dear Dynon,
I have a D10A in my RV7 - I first flew it in 2005 and I love it. But... I just encountered a strange problem. I'd appreciate any guidance you can offer.
Symptoms:
[olist][*]At my 50' elevation field, I dial in a 30.11 baro reading and the altitude display is correct.
[*]Start takeoff roll, on climbout look down and see that the altitude display says -1200(ish) feet. Also notice that the wind vector display (from airspeed vs GPS correlation) says that the wind is about 70 mph (wind was calm).
[*]Dynon airspeed display is fine.
[*]Conventional 3 1/8" airspeed and VS seem correct.
[*]Notice the problem, fly around the pattern and land.
[*]In runup area, I power cycle the dynon and after boot it comes up with a default baro setting of 28.77 (presumably because it adjusted the baro to whatever it needed to get -1200'). Change baro back to 30.11, see that the altitude display is correct again at 50'.
[*]Take off, same problem happens. Land.
[*]Taxi back to hangar and feel various pitot/static lines behind the panel - they feel okay.
[*]Make this post
[/olist]
Any tips on what could be causing this new behavior? Other relevant datapoints:
[olist][*]About 400 hrs on the unit.
[*]This was the _second_ flight after maintenance where I removed my primary panel (disconnecting and reconnecting pitot, static and AOA lines. These lines are routed to the dynon, an Altrak, a VS and an airspeed indicator). I use the dynon as my altimeter.
[*]The previous flight was fine - flew for about an hour with no problems.
[/olist]
I'm not suspecting the Dynon per se but possibly a system problem.
Symptoms:
[*]Make this post
[/olist]
[/olist]
