it could be that i am right on the fringe of quality reception with a belly antenna, in a metal hangar, at the far end of the airport, but with the radio stack -on- atis comes through quite clearly. the sl40 reports a signal of 50 or so and noise around 20. it breaks the squelch setting and sounds pretty impressive. turn on the skyview and a significant layer of noise swamps the signal... to hear it at all you have to pull the squelch and strain to hear the words though the noise... in numbers the sl40 reports noise at 130...
hours of testing...
the noise is from the screen unit... unplugging the connections to the gps antenna, the ems, and the adahrs has no effect on the rf noise.
the garmin 696 also increases the noise level but not as much... by ear perhaps half as much...
turn off all power in the hangar and the noise level is reduced somewhat in any configuration....
open the middle hangar door and the atis broadcast becomes audible with everything on. the sl40 reports a noise level around 100.
push the plane forward a couple of feet and it gets clearer still... reported noise drops to around 80.
turn the screens off and the noise drops to 7...
after extensive testing it is pretty clear that both the garmin 696 and skyview display put out some level of rf interference. they do not produce any noise on the intercom, with music inputs, or when transmitting, only on a radio signal coming in.
i wanted to push out of the hangar and test in the open but the weather was not cooperating.
all and all quite frustrating.
how much rf interference is expected with the skyview? how to measure it or characterize it?
can anything be done to mitigate it?
hours of testing...
