So we're looking into other possible root causes, but one thing that could definitely cause this: One of the checks we're doing here is the AOA sensor against the Pitot sensor. Ostensibly they should be the same at rest, but if you don't have AOA installed, and do have a dust cap on the AOA port that is completely sealed, you might have some pressure on the AOA port that is causing the system to think that there's an air data sensor problem. The dust cap that comes pre-installed from the factory is drilled for venting, so we don't think they ship in that sealed configuration. So one thing to check (again, if you don't have the AOA pitot installed) would be whether or not there's something completely sealing the AOA port on the ADAHRS. If you do have the AOA/Pitot installed, this wouldn't be an issue because both the pitot and AOA lines would be vented to atmosphere.
