Jamie
The pilot side screen boots and has ver3.1 install.
This screen has one SV32 and the ADAHRS in one SV-net with a splitter.
The other SV net connector on the same screen has another splitter, one side goes to the ems , and the other goes to the 2nd screen.(co-pilot)
The 2nd screen gets its input sv-net from screen 1 and has another sv32 on the last sv-net port.
I have been into the wizard on screen 1 and it does find the sv32 that connects into the 2nd screen.
The wizard shows
1 x d1000
1 x ems
2 x sv32
1 x adahrs
But it never finds the 2nd d1000.
I pulled the 2nd screen out, and put it into the pilot side. It boots up fine and has ver3.1 installed.
So I then put the pilot side screen into the co-pilot side, still will not boot.
I have held down button 1 to turn it on, nothing happens.
I tried another cable direct sv-net from screen 1 to screen 2 (no splitter ) and screen 2 still want boot ( turn on ).
Every thing on screen 1 works, ADAHRS, GPS , EMS, SV32.
What volts should I see on each SV-net pins. I do see around 5volt on some pins.
Any help pls
*** do I need SV-HARNESS-D37 into both screens *** as I have only one into screen 1
The wizard shows
1 x d1000
1 x ems
2 x sv32
1 x adahrs
Any help pls
