Dumb question again
rickw
Ok I must be the slowest guy on the block. Can someone advise me what I need.
io320 is hung. I believe I need the ems kit l4f right? But, that does not include a fuel flow transducer right. I have heard the red box is better than the other brand, but cannot find clarification which one is sold here and if I should source elsewhere.
Further, i am planning on one 10" skyview so just trying to wrap my head around what other cables/harnesses I should get now is kind of frustrating. I will have one adahrs, one ems module, one map 270 when available, one gps-250, one new-10cp, one battery 320- and then my ap servos x2. So how would I guess how many harnesses I need? I am thinking of just getting the ems kit now and waiting until I get a clue about the rest of this. Anyone else have trouble wrapping their head around figuring this out? I hate placing 7 various orders and still missing stuff. :-/
schristo
you will need a harness from the ems to the dynon screen... the 3' cable with both ends terminated will likely be perfect.  also, you will need to get a connection from the screen to the adahars... the location is up to you but will likely be behind the baggage area so you will need to select a cable long enough to reach... i chose the 20' cable (only one end is terminated) since the price difference is quite small between lenghts.
the red cube is currently standard from dynon but is an extra cost from the basic ems.
What Stephen said!
The red cube Fuel Flow Transducer is an EI (Electronics International) FT60 for $200.
The two network cables are as Stephen suggested for the EMS and ADAHRS.
The hard part are the servos.  You need to run your own seven wires from each servo; 1 to power, 1 to ground, 1 to a quick-disconnect switch on your control stick, and 4 connected into the nearest SkyView Network connection (typically a Display or ADAHRS).  You will probably need Network Splitters to make those Network connections.
You can read more, and download a servo wiring diagram, on our Wiki at http://wiki.dynonavionics.com/SkyView_FAQ.
schristo
servo wiring diagram - file not found error
there is a problem downloading the servo wiring diagram on the wiki... it gives a file not found error.
Oops, I mis-typed the address. Now try it.
-Robert
Dynon Marketing
