Dynon CONVERTER
OY-9319
Hello
Almost done. Everything is working except ALT read out.
Need help! I have Garmin GTX 328 xponder. Moved out my AK 350 encoder and bought Dynon converter (without knowing that is possible to use only one wire from SV to Xponder). Wiring is exact but I do not have ALT read out on xponder.
SkyWiev is programmed. Used Serial 1, with settings: None, None, 1200, Dynon Converter.
Tryed to change settings in 328, without luck.
What kind of settings change do I have to make in xponder.
HappyLandings
OY9319
I'd really suggest hooking the 328 up via serial. It's only one wire instead of 13 or so, and much more reliable.
If you do stay with the converter, we don't have a lot of experience hooking these to 328's since nobody does that. I'd just double check wiring and make sure the converter has power.
OY-9319
Thanks for your reply.
Wiring is dubblechecked and should be OK.
I have tryed to connect it with only one wire too. No respond on xponder.
Any suggestion how to test if converter is working?
OY-9319
Hey Jake...
I think so... but if you have experience, tell me please.. I beleive that 328 and 327/330 has same platform... How did you do it?
Just need to confirm how you have it (GTX328) wired up now from the Dynon - are you using the 1 wire serial or multi wire converter ?
OY-9319
Hello
I am using multi wire converter at this time.
Thanks for helping out
OY9319
OY-9319
No result. Had a men check it all. He is working with avionics on chopers in the army. He sad, that there is no life in the converter... :(
Suggest you go the one wire serial method which would have been much easier to wire up and less chance of faults rather than the multiwire converter method.
However I've not heard of a problem with the converter - suggest you check the wiring carefully if not done so already ;)
OY-9319
Hey
Got Alt readout with one wire... Nice. But not knowing the posibility, I bought converter. I am not sure, if converter will in future have som usefull funktion.
Had a avionics technician looking at the converter and SkyView.
He wrote:
ATT:
To whom at Dynon Avionics it might concern.
Subject:
Suspected faulty Serial-to-Grey Code Converter (Dynon P/N 100362-000)
Fault description:
A Dynon Serial-to-Grey Code Converter fed by a Dynon SV-1000D Skyview Display, fails to feed a Garmin GTX-328 transponder with valid Mode-C Altitude Grey Code.
Observations:
The Garmin GTX-328 transponder detects all 9 Grey-Code discretes (A1,A2,A4,B1,B2,B4,C1,C2,C4) from the Dynon Serial-to-Grey converter, as steady "OPEN" state.
This has been re-confirmed, at all times, by measuring aprox 4,8 Volt's on each of the Grey-Coded outputs mentioned above.
Disconnecting the Serial-to-Grey Code Converter from the Skyview Display serial port, results in no change of the Converter Grey-Code output discretes. (all still "high/open")
The Garmin GTX-328 transponder runs flawless when provided with Grey-Code from an Amer-King AK-350 Altitude Encoder.
System Scenario:
The Dynon Serial-to-Grey Code converter are connected to Serial Port 1 of a Dynon SV-1000D Skyview Display, as per the SV-1000D instruction manual Page 9-12, Figure 25.
SV-D1000 37 pin D-Sub male. (see Instruction manual Page 12-6, Table 25)
Pin 3 Serial RX - connects to Dynon Serial-to-Grey Code converter Transmit GREEN Wire.
Pin 4 Serial TX - connects to Dynon Serial-to-Grey Code converter Receive BLACK Wire.
SV-D1000 Serial Port No°1 has been choosen, and Encoder Format has been setup as per the instruction manual Page 9-11, mid text-section.
Serial 1 IN Device: NONE
Serial 1 IN FUNCTION: NONE
Serial 1 IN/OUT BAUD RATE: 1200
Serial 1 OUT DEVICE: DYNON CONVERTER
The Dynon Serial-to-Grey Code Converter are provided with power by means of a switched Voltage from the Garmin GTX-328 transponder.
The presence of this voltage has been re-confirmed by measuring 12V DC between the Red (posistive) and Black (negative) wires going
to the Dynon Serial-to-Grey Converter. The power are present whenever the Garmin GTX-328 transponder are switched ON.
Both Dynon Skyview Display and Garmin GTX-328 transponder are grounded at a common Avionics power ground point.
Conclusion:
We have no means of checking if the Serial RS-232 Data Bus transmitted from the Skyview Display are valid/present - except from beeing
able to re-confirm a presence of an alternating current on the Bus, by means of a simple Digital multimeter.
The TX-Counter on the Skyview Display Serial Port 1 setup page, are observed as steadily advancing in number.
This leads us to suspect the Dynon Serial-to-Grey Code Converter as beeing unserviceable/faulty.
For everyone's info, we found a bug in SkyView where the Dynon converter output stops working after a few minutes, which of course makes the converter look broken.
Direct serial to a 327, 328, or 330 is unaffected.
llacy
After wiring the Dynon converter to the Skyview the altitude encoder doesn't work. I get a transmit data readout. Do you have a trouble shooting idea. I am wiring the converter to a KT76A
Are you running 1.0 or 1.5 firmware? The 1.0 firmware has a bug and the converter doesn't work always.
llacy
Concerning the wiring from the encoder coverter to the DB37 connector. Does the green wire from the converter go to pin 3(brown with violet stripe) or to pin 4(brown with orange stripe. This is assuming you are connecting to Serial Port 1. Also can the black wire coming from the converter be connected to any of the black wires coming from display DB37 connector
Brown/orange, assuming serial port 1. The Dynon needs to TX to the converter module. Ground works as you describe - grab it anywhere you'd like.
llacy
I have given up on making the converter work. I am going back and use my blind encoder wish I had never tried the converter!
