DYNON HDX Airspace Warning
RV7Builder
Hi, just to be sure, is it right that the Dynon HDX itself is not warning if you fly into an airspace which need apermission like D,C ?
Using the latest Database hte airspace isimplemented buit i do not get a warning. When using easy vfr on my mobile i get those warnings.
Nice greetings
David
F18Sailor
I fly the Skyview classic, so maybe not the same as the HDX, but with ADS-B in it will display the TFR's: https://dynonavionics.com/traffic-weather-adsb.php
You may need to go into the menu and change the opacity. Stadium TFR's are also loaded by default, but they will basically always appear, even if not active, and the list is a little bit dated (circa 2015).
Personally I don't rely on Skyview to keep me out of TFR's, but part of that is my home field is located in the SFRA, so I have the opacity turned down so I can see the Class B airspace below it.
RV7Builder
Yes maybe my message was a litte confusing. I just wonder if there is a possibillity to use my Dynon HDX as a Naviagtion system which warns me not to fly into an airspace charly for example or not. I can see the airpsaces in my dynon but there is no warning.
nice greetings David
ned
Even more important, as far as I know there are no warnings for obstacles, other than traffic.
