thibault
- Joined
- Oct 25, 2009
- Messages
- 191
This question is for those of you that have the heated AOA pitot tube and have installed per page 15-7 of the manual.
Do you see the EMS widget cycle between ON and OFF during normal operation? I swear that I used to see that, but now it always says ON unless I pull the C/B. Then it says OFF like I would expect.
To verify that it really is cycling the heater, I put a jumper in the plus voltage wire and measured the current. When the hangar is 80F and I turn on the master, the meter shows about 6.7 A for a few minutes, then drops to 66 mA. Then it goes through repeated cycles of 6.7 A and 66 mA.
The probe gets hot enough that you can't hold it for long, but it sure does not feel like 80C. Is this all normal?
