johnso29
Dynon Skyview shows Negative amp irratically of between -4 amps and -56 amps.... Voltage shows reduction from 14.5 volts down to 12.4 volts.
I agree with Airguy, my ‘short circuit’ incident suddenly manifested itself , after 18 years, with the Aternator ‘B’ wire massively shorting out & cut through #1cyl temp probe.Are you saying that the voltage is dropping at the same time the amperage is going high? That would indicate a short circuit somewhere.
“Afaik- the PMA’d Plane Power Alternators do not have the ‘issues’” - I’ll have to talk to the LAME who told me thisThe PMA ones in fact do have the same problems.
One of the operators I look after changed out his fleet (twin pistons) to Plane Power.
The aircraft operate remotely, and come back for scheduled maintenance.
The amount of flights we had to take to site, to swap out dead alternators made him remove them all and go back to the originals.
He has a large box in the workshop full of PP alternators, unless he's already thrown them in the skip.
Their external voltage regulators like the R1224 are really good, but the alternators are as bad as the experimental ones.
