AFAIK the GPS-250 only drives the Skyview screen, and the ADS-B-472 gets all of the ADS-B IN information. The only link between the two is where traffic or weather is displayed on the screen. What GPS is used for ADS-B OUT is a different issue, and must be compliant with the reg requirements, whether a GPS2020 or a certified panel mount GPS. I use GPS-250 to drive my screen that gives all IN information, while using a GTN-650 to drive the OUT through the 261 transponder. Works fine. The ADS-B IN information is not limited by using the GPS250 to drive the screen display, as the GPS does not receive any ADS-B information, just GPS position, track, speed and altitude.The ADSB-472 is an ADSB IN device so you can use the SV250 to receive limited ADSB data. You can NOT use the SV-250 as the GPS source for ADSB OUT. For that you must use the SV-2020 or another ADSB compliant GPS.
That is EXACTLY what I said: "You can NOT use the SV-250 as the GPS source for ADSB OUT. For that you must use the SV-2020 or another ADSB compliant GPS."AFAIK the GPS-250 only drives the Skyview screen, and the ADS-B-472 gets all of the ADS-B IN information. The only link between the two is where traffic or weather is displayed on the screen. What GPS is used for ADS-B OUT is a different issue, and must be compliant with the reg requirements, whether a GPS2020 or a certified panel mount GPS. I use GPS-250 to drive my screen that gives all IN information, while using a GTN-650 to drive the OUT through the 261 transponder. Works fine. The ADS-B IN information is not limited by using the GPS250 to drive the screen display, as the GPS does not receive any ADS-B information, just GPS position, track, speed and altitude.
