I am flying in a flight club and as flight clubs normally use the tachotime to charge the different pilots there exist a need to get tacho reading with 1/10 and 1/100 hours to be compatible to the other aircrafts equipped with "normal" tachometers. Otherwise there will be a false charge that theoretical can be as high as 0.2 hrs. This matters when you have to pay the bill. As I work with electronics systems I can easily see there should be no problem to implement this change. Hobbs time does not work the same and also lacks the 1/100 digit. Question to Dynon: Are your intention to "fix" this ?
