The Skyview Installation Guide says "The pressure port on the
manifold pressure sensor requires 1/4” inner diameter tubing...", but Dynon's Product Ordering Guide lists the MAP: 100434-000
1/8” hose, 0-60 In Hg. $65. Which hose size does the MAP accept.
Also can I use a replacement MAP Sensor with the same specifications as Dynon's 100434-000 to connect to the SV?
