Dynon's MAP
doug
The Skyview Installation Guide says "The pressure port on the
manifold pressure sensor requires 1/4” inner diameter tubing...", but Dynon's Product Ordering Guide lists the MAP: 100434-000
1/8” hose, 0-60 In Hg. $65. Which hose size does the MAP accept.
Also can I use a replacement MAP Sensor with the same specifications as Dynon's 100434-000 to connect to the SV?
Doug
It is 1/4' tube size in both cases, you may need a reducer at the engine end. Another good idea is to include a 'snubber' at the engine end as well ie make a fitting (aluminum rod) with a tiny hole then insert this into tube at the same end, this will smooth out fluctuations in the MAP readings when adding/reducing power.
Same specs is ok - Dynon has mentioned this is the same as a particular GM unit.
