C
Charles Spinelli(Guest)
Guest
I built a HUD optical system that mounts on the EFIS D10. The system consists of a 45 deg silvered mirror to project the image vertically thru a collimating lens and then projected on to an 80/20 beamsplitter mounted in front of the pilot. As a result I have the EFIS display overlayed on my forward field of view. The system is cheap light weights about a pound and removable in flight.
I sent some pictures to the canard aviators user group and got a huge flood of emails on guys wanting to do the same thing. There are a couple of issues I need to work out the main one is brightness on a sunny day. In very bright sunlight the image will wash out but on cloudy days or evening flights and at night it works great.
I think I have a solution for increasing the image quality/brightness but it will require your help. In a nutshell if the display can be modified to project the image in a bright green (Like real HUDs) I can get the optics coated to reflect the bright green waveband only and that should increase the readablity in bright sunlight. Also is there any way to increase the brightness of the display without damaging the unit.
I you guys are interested in seeing what I have done I'd be glad to show you, I can even send some of the pictures ifyou like. I live in the Seattle area and my Vari-Viggen is located at Renton Airport.
Charlie
Charlie
