vlittle
- Joined
- May 7, 2006
- Messages
- 545
Yesterday, I had several of my EGT probes start to misbehave in flight. I've determined that the fast-on connections are the problem, so I reseated them and coated them in Corrision-X and will fly again.
They all started to misbehave at once. On the ground, here's what I got. First, the odd cylinders were bad. After a power cycle on the SV, I checked again and the even cylinders were bad.
I'm almost convinced that the connections are the root cause, but this is pretty odd behaviour. Is there something about the EMS input structure or system grounding that could be at issue here?
And yes, I see the CHT is wrong in the first screen shot... same root cause?
Vern
Vern
