No engine start yet.
Went back to what I adjusted last, which was splicing into the Pin 15 of DB37, the Fuel flow 12V red wire.
With the splice and hookup to the cap volt convertors (not hooked to tank), I get the faulty reading on all CHTs and EGT's of -99. I removed the ground associated, no difference. I remove pin 15 from the DB37, replace the harness into the D180 and presto, Normal CHT and EGT reading the ambiant hanger temperature.
Any idea what could cause this?
Once the pin is removed, all good.
