Mark_Dickens
- Joined
- May 20, 2012
- Messages
- 86
I have an older EMS-220 box and it has the flaw in it that causes the EGT/CHT readings to go off scale when I key my mic. I know I can get an warranty replacement, but its a real pain to get to and I want to explore any possible fixes without having dig it out. My question is "can the ground wire (pin 3) act as an antenna if exposed to RF and generate these errors?". The ground wire is currently run in front of the firewall to a common ground collection point, but I could relatively easily re-route it behind the firewall to the same ground plane. If this isn't what's causing the problem, then I'll have no choice but to dig it out, but I would love to avoid that hassle.
