thibault
- Joined
- Oct 25, 2009
- Messages
- 191
Support,
A little birdy says this data (Installation Guide, Section 18) is the same as or similar to the legacy products. Is true? If so, are there already existing tools to decode and make use of the data? Could do my own, but I'd rather beg, borrow, or steal.
Regardless, it seems there are some errors in that new section:
1. Data Version is given as two chars starting at position 3, but Zulu hour starts at position four. If really two chars, then the example at the end has version 11 and the zulu hour as 83.
2. The rest of the start positions are off by one down to Thermocouple 3. Thermocouple 4 is right and then Thermocouple 5 through the end are not. So Checksum is at 219 and the note should say "..all 218 preceeding..."
4. CR/LF is 220 not 177
5. What is the minus sign at char 15?
6. What is the plus sign at char 54? Is that plus .7A. Note does not say plus sign is used.
7. At char position 68, 72, 76, it must have been really cold that day!!!!!
So, is this a real data capture from Version 3.1 or is it made up? We either need correct documentation or existing tools that work.
Not bitching, the product is really good, but I get beat up at work when I don't correctly document my work.
Thanks,
Tom
Back to my first question, has someone already built tools?
Thanks,
Tom
