I bought a Jabiru J230 with a brand new 3300 engine fitted with Dynon EMS10 and D100 EFIS. The oil temp has been indicating a very high temp (100c-110c in cruise and higher). I finally checked it with a separate analogue gauge and sender and determined that the EMS10 was inaccurate as the analogue gauge was reading 83c in cruise. I then checked the anaologue gauge in boiling water and it was dead accurate.
The EMS10 was set correctly to the Jabiru sensor so I tried a second sensor and it made no difference. I decided to purchase and fit a genuine Dynon sensor p/n 100409-000. Once fitted I set the EMS10 to the Dynon sensor and went for a test flight and found that the EMS10 is still over-reading by approx 13c ie no change. Can the EMS10 be re-calibrated as it is obviously very inaccurate?
Any advice would be appreciated.
