Engine panels swapped position
dlevy52
My Skyview HDX mysteriously swapped engine panels at the bottom. I don't see any way to swap them back. How can I swap the lower engine panels?
Schorsch
I suspect you'll have to go back into SETUP and move around the sensor widgets.
It's the layout. Page 4-29 of the installation manual.
wilkersk
Very similar to what happened to mine. I posted a video in my earlier thread that showed the right and left halves of the EMS bottom band swapped. The NAV ribbon also swapped sides. Since the main PFD element group goes black when "Menu" or "Display" buttons are selected, theres not much more I can do except try and go to EMS setup menu and try to swap everything back. But that doesn't fix the bigger problem for me.
bleighty
I don't remember the setting but it looks like maybe the swap of left and right sides setting. Notice your map also doesn't have the expansion button either. If you switch that back I think that should solve it.
