Excessive static in intercom when PTT used.
Davesplace
No problem receiving transmissions, however when sending, excessive static in intercom. Suggestions?
Davesplace
Can receive transmissions clearly but if PTT pushed, excessive static in headset, cannot distinguish the transmission. Any suggestions?
Dave
There can be so many variables here but here goes --does this happen when engine is not running ? if yes then turn everthing off except radio & intercom then try again.
If yes to static then it's possible that there are some wiring issues, if no then turn on each electrical/avionics (those that you normally have on) item one at a time to ascertain the result - better still I'll pm you  ;)
Jake J
Sportsman7064
Clinton, AR
Just starting taxi tests. With the Dynons off, the Garmin radio stack works very nicely (PMA240 audio panel, 430W, SL40). Once the Dynons come online, there is a substantial amount of static in the background and I'm unable to squelch it away (regardless of if the PTT is depressed). I can hear incoming transmissions over the static, but I'd like to eliminate this.
Any suggestions on what to look for?
Thanks,
Russ
Hi Russ,
You need the filters from Dynon.  Contact support and they will arrange them for you.
regards
Trev ;D
Hey Trev
It may not be the filter replacement you describe, depends on other things too including serial number of unit , it may be the EMS module too - best bet is to contact support direct IMO ;)
Jake J
trevpond
Nottinghamshire U.K.
Oh well Jake,
At least we agree on the support, but filters have always been my number one - it happened on mine.
Have a great Christmas, and hope to see you over here next year.
regards
Trev :D :D
iflyaz
I also get an audio buzz in the intercom. It comes from the display - it is quiet at full dim and full bright but buzzes in between.
Not really noticeable when flying but can hear it on the ground.
I put 4.7K resistors in series with both audio channel outputs and raised the volume in the settings, this helped a lot.
