Expansion module ideas
khorton
Ottawa, Canada
I am very happy to learn about the HSI 34 expansion module, as I have a GNS 430 that would need to use with an eventual D-10A as an EHSI.  However, I am quite dismayed to learn how large the HSI 34 is.  I have some space left in my panel, but not nearly enough to fit this monster in.  I would need to cut a whole new instrument panel, get it powder coated and silk screened, etc :(
I know Dynon is working on other expansion modules, so perhaps you have something in the works that would better meet my needs.  If not, I offer the following comments as ideas for future products.
1. I suspect there are many people like me - they have a GNS 430, want to feed it to a Dynon product, but have no more panel space available.  Why not make an interface box with no instrument panel interface?  Sure, you wouldn't get the nice knobs, or the bearing needle switches, etc.  But, you could at least use a GNS 430 without sacrificing any panel space.
2. Why not make a smaller version of the HSI 34?  Does it really need to be so big?  As a reference, I measured the spacing between adjacent knobs on a Canadair Challenger CL-604 - the knobs on the lighting control panel are 0.5" diameter, and spaced side-by-side on 1.333" centres.  The only vertically stacked knobs I could find are of similar diameter, but spaced 1.5" vertically, centre to centre.  It should be possible to make much smaller, but still usable, control panel.
3. If you can't make the HSI 34 smaller because you need to the volume to fit all the electronics, then how about making a smaller control head that just has knobs and buttons.  It would connect to a remotely mounted box that had the bulk of the electronics.  It should even be possible to make this remote box be the same one as discussed in comment 1.  If a knob and button box was connected to the remote box, it would respond to them.  If no knob and button box is connected, the remote box simply interfaces the GNS 430 to the HSI.  If you did this, I would purchase the remote box so I could feed a GNS 430 to a D-10A.  Later, when I was prepared to redo my panel, I would purchase a cockpit control panel to hook up to the remote box.
4. You could publish the spec to allow third party knobs and buttons to connect to the remote box mentioned in comments 1 and 3.  This would allow installers to use buttons and knobs that matched the rest of the instrument panel.
5. As others have mentioned, a horizontal orientation would be popular.  But, for those with D-10As, it would be a bonus if the expansion module width matched the width of a D-10A.  That way the expansion module could be mounted right above or below a D-10A.  There should also be an available spacer that would go between the expansion module and the instrument panel, to put the aft face of the expansion module in the same plane as the aft face of the D-10A.
6. A cockpit control panel with just the heading knob, course knob and the bearing and nav source buttons would be nice, with a second control panel that just has a Value knob.  The first control panel would be mounted near the EHSI, and the second one near the EADI.
7. I saw an interesting cockpit control on the Dassault Rafale demonstrator way back in 1988.  There was a knob similar to your Value knob, but there was also a concentric outer ring.  You selected which item you wanted to change by turning the concentric ring.  Once you had the correct item selected, you spun the knob to change the value.  When you had the value you wanted displayed, you pushed the knob to enter the value into the system.  A few seconds after you pushed to enter, the system timed out, and the data entry field on the HUD would disappear.  If you turned the Value knob again, the data entry field on the HUD would be displayed again, with the item that was last used displayed.  If you wanted something different, you would turn the outer ring to cycle through the different items.  You could use a similar interface with the Value knob on your system.  This would be quicker and easier than using the buttons on the EFIS to select the item to be changed, then moving the hand to the knob to change the item.
Without dissecting the reasons behind every product decision we make, in a nutshell:
1, 2, and 3, and 6 are not likely. While we would love to be able to support all possible physical configuration to hit all the corner cases, it just isn't really possible to do so and keep our products affordable at the same time.
4 is not a possibility.
As for 5 - a horizontally oriented version wasn't planned, but we may rethink that after hearing this request a lot at Sun 'n Fun from our existing customers. If done, it would be exactly the same size as the current hardware (which is a bit wder than the EFIS-D10A).
That Dassault interface sounds pretty similar to the 430/530/g1000 interfaces. As we expand our product line, we'll continue to do our best to try to keep our interfaces simple and intuitive.
Thomas_Schaad
I do agree with Kevin in all aspects. If Dynon wants to sell this box, they need not only to bring a superior product, that gets customers attraction, it also has to be possible adding it to an existing panel with minor mods. This was finally for sure one of the reasons for the big success of the D10 and also why I started to install Dynon.
About the expansion modul, I for my part did aleady decide and the decision is NOT to cut a new panel just for a modul, that has meassures which are different to the rest of the instruments. If it's not possible any smaller or split, then it should come at least in a standart 2" or 3" instrument size box or radio stack mount. The actual way, sorry guys, good job but no interest.
Kind regards
Thomas ;)
PilotKris
I agree with Kevin and Thomas.
A smaller "control panel" would be a HUGE help for those of us who have limited panel space.
S-Tec had the same situation when they introduced their GPSS. They offered two versions, an all-in-one box and a remote mounted box with a smaller panel mounted control. So successful was the remote version, they no longer offer the all-in-one unit.
PilotKris
While my sugestions got shot down in another forum, I thought I'd leave it here too.
While the new expansion module has LOTS of kewl features (like all the I/O ports), I think that most people who have a D180, SL30 and 496 (fast becoming THE standard panel for LS and smaller experimentals) would simply like to have the source switches, course knob and heading knob. All of the other features are in the "nice to have" category as opposed to the "need to have" category.
How about a "simpler" (and smaller footprint) product that just provides remote HSI source selection, course selection and heading selection? All that would be needed would be a single coaxial knob with push switch (ala Garmin 430/530). The outer knob for course, the inner for heading and push for nav source selection.
While this would not allow for any annunciation, who needs it? One only needs to look at the HSI to see what is selected.
There you have it, all of the most desired functions in less than one square inch of panel space.
