I am unable to calibrate my EDC-D10A to my D10A EFIS. I have sent the EFIS and the remote compass to Dynon for syncing the firmware and testing because of communication problems. They were returned to me without any explanations about their status.
I must assume that both were working fine, the syncing was done and the issue is with my installation although it would have been nice to get a confirmation it was done. I re-installed both and it still not working.
My setup
EFIS-D10A Sn:5745
EDC-D10A Sn:9071 part:100323-000
OAT
Symptoms:
EFIS detect remote compass and OAT. Windows firmware update software finds EFIS but does not detect EDC.
EFIS displays accurate OAT readings.
EFIS displays a wrong starting heading, heading changes when turning than slowly returns to original heading. It seems locked with a heading of about 200 to 225
Lately tried 5 calibrations, all failed but 1. Even with a successful calibration, EFIS heading is not working. See previous line.
remarks:
I asked Dynon to sync EFIS and EDC firmwares as I knew it was wrong. They never told me if they did it or not. They might still be out of sync.
I tested all EDC to EFIS pins and they are OK meaning the right EFIS pins connect to the right EDC pins based on most current documentation.
I have a concern regarding the grounds (OAT and EDC grounds) Pins 1 and 8 connected but also soldered together outside of DB-9.
It looks like an original Dynon cable but I see I was cut and reconnected halfway by the previous owner for an unknown reason.
Questions:
Pins 1-2-5-6-7-8-9 of EDC DB-9 are used. OAT used 2,7,8 and EFIS sees OAT, which leave pins 1-5-6-9 to communicate with EFIS. I have to assume that EDC receives power(6) and the ground(1) is also OK because OAT is powered and provides a reading to EFIS. This leaves me with data A and data B pins (pins 9 and 5) for potential error. Which data cable does the EDC uses to send OAT readings to EFIS?
I read that some DB-9 pins changed over the years/product versions. I am testing the pins using the most up-to-date documentation. Based on my EFIS and EDC serial numbers, Am I correct to use the most recent pins layout or should I use an older pins layout?
Am I right to assume that, as the Windows firmware update software does not detect my EDC, there is a defect either with the EFIS, the EDC or the cable. The installation is not part of the equation at this point in time?
What would be my next test?
Thanks for your help
My setup
EFIS-D10A Sn:5745
OAT
Symptoms:
remarks:
Questions:
