Flickering widgets
OK, it definitely is NOT my imagination or aging eyesight. I am seeing occasional flickering of widgets such as RPM, MAP, etc. Not very often, but it's there...portions of the widget disappear for a fraction of a second, then reappear, sometimes several times, then all is okay.
Also saw the NAV data from the GPS/ARINC disappear a couple of times for maybe 1/2 second. I believe that is a separate problem that Dynon knows about.
Flickering portions of a display mean, in my experience, that the display routine is not getting a high enough priority in the software, and the drawing/display is not being given enough time to finish before another process interrupts it.
I grabbed a diagnostic file and can provide it.
Hi Steve - The best way to troubleshoot this from here is to get in touch with our support team at support at dynonavionics dot com.
I will do that first thing in the a.m. Appreciate the quick response, and hope the data can help you find the cause of the issue!
