Flight Plan Source Option
jnmeade
Eastern Iowa
I have dual 10" SVD1000T and the Garmin GTN625. I do not get the option to select the 625 in the window near the HSI icon. I used to get the option for SV or the GTN and for some reason it is not present now. I suspect I made a setting entry in error but I've looked in the manual and have gone through the avionics settings and am not seeing it. I'm sure I'm overlooking something.
Can someone suggest where to look for my error?
Again, I get the SV option but not the GTN option in the box by the HSI.
I've activated a flight plan in the GTN.
skysailor
It is likely you just inadvertently turned it off. Go into the PFD menu then look for BRG 1 and BRG 2 buttons. These cycle the inputs among your sources for what each bearing pointer displays. On mine, the choices are VOR/LOC, GNS 480, and Skyview. The trick here is that if I go one further the needle is removed which means the last choice is not displayed but is actually OFF. The nomenclature (VOR/LOC, GNS 480 etc) is set by you in your ARINC settings so you can call them whatever matches your configuration and needs. If you are trying to have the autopilot navigate from the GTN625 you will need the HSI Source to show that.
