FLP reverse
Pegaz
France
I am a flight with an FPL on the MAP and the AP. For the return, I did reverse FPL from the field but the function "Navigate" was not operational. I tried to reload the FPL with the WI FI and it does not always work. I do not understand what happened. :-[
I'm not sure if there's a good reason for this (I can't think of one), but I'm seeing what you're seeing. There are two ways to get going - either use FPL MENU > ACTIVATE LEG, and that will both activate the leg and start navigating. Or, while on the FPL menu, you can just highlight one of the waypoints and hit the direct-to button to get a direct to that waypoint (and then continue on in flight plan sequence).
preid
SoCal
Used to work that once Fpl was complete it automatically setup the first waypoint . In a upgrade, 10 perhaps, the requirement to use the two manual (extra step ) was instilled. Sure there was a good reason for this, as was said, can't think of one or why..
