Foreflight europe aviation data and obstacle
S5_aero
I found out there is Foreflight available now for Europe.
Anyone here using Foreflight can tell if Foreflight provide aviation data and obstacle data for Dynon Skyview?
also can vfr charts be used on Dynon usb stick to view them on Skyview directly?
I love aviation!
Foreflight does not provide any data into the Dynon system other than flight plan transfer via WiFi. It also supports pulling the flightplan into Foreflight from the Skyview but requires different actions in FF.
VFR chart data, in the US, comes directly from Dynon (not FAA charts). If you want the standard FAA charts (VFR and IFR) Dynon supports them via a subscription with Seattle Avionics. Doesn't appear they support anything outside the USA.
http://www.seattleavionics.com/ChartData/default.aspx?TargetDevice=Dynon
AlanR
UK
In Europe you need to be using Pocketfms EasyVfr for chart and Nav data. It is the only system that is fully integrated for use with your Dynon Skyview.
http://www.pocketfms.com/
S5_aero
thanks for info.
if i cant use it for nav data for dynon also it is useless for me. then pocketfms is the way to go.
