Franklin engine EMS system installation
pnwpilot
Hi John,
I have a Franklin 220hp 6A-350-C1R on my experimental Velocity. My A&P and I installed the EMS package on my engine a few years ago. Happy to help answer any questions.
JohnMauleM4
Hi,
Thanks for the reply. Do you by chance have have any pics of the manifold pressure sensor hook up?
John
pnwpilot
Hi,
John
I don't seem to have any good pics of the install but my MAP sensor is mounted on the hot side of the firewall and is connected to the #2 cylinder's primer port. I mounted the sensor a bit higher in elevation than the primer port so that any fuel/oil mist that condenses in the line pools at the bottom of the MP hose near the port making it easier to clean out. I also installed a MP restrictor fitting from Van's aircraft to dampen the pulses (and to help keep fluids from getting into the MP line). Not sure what you can use for a certified install but I would highly recommend installing a restrictor if at all possible.
