ft- 60 red cube not reading anything
tlb67
I have gotten the fule flow transducer hooked up but i get no GPH reading in the 180
i have checked and rechecked the wiring all correct but still no go .
any suggestions?
A few things to check:
-Is the fuel flow sensor actually getting 12V from either the D180 or ship's power?
-What's your K-factor set at?
tlb67
im going to recheck that it is a full 12 volts and i have the k factor at the 68000 setting thats called for in the install sheet
tlb67
I have check wiring and k factor and everythings good but still no GPH reading,i can unkook and hear the wheel turn with a little pressure .any other sugestions?
First test: Tap ground the wire going to the fuel flow transducer against ground, a few times a second
This should show flow.
If it does, and there is 12V at the transducer, the transducer is bad.
If tapping the wire against ground causes no flow, then you have a wiring or D180 issue.
