SkippyDiesel
- Joined
- Nov 24, 2024
- Messages
- 76
Yes & No - I purchased the incomplete, plans built, Sonex Legacy from the original builder and finished it. Under Australian rules, I am listed as the builder. It's been in the air for 132 hrs now.@SkippyDiesel are you the original builder of your plane?
The aircraft came to me as an almost comprehensive "kit" in that I have had to purchase very little - the fuel metering system being part of the initial purchase.
While I understand that having the two Red Cubes has the potential to improve the accuracy of fuel flow (an aid to engine power setting) I am beginning to wonder if its complexity outweighs its benefits.
My last aircraft had a single, impella style, fuel flow metering system - "easy as falling of a log" to calibrate. Gave reliable total fuel used and useful, inflight, indicated flow.
Before this aircraft was flown, I did fuel flow calculations - the return fuel line delivers, through a restrictor jet, a fairly consistent 7L/hr, back to the header tank. Rotax publish expected fuel consumptions at various power settings - the figures give me a baseline from which to assess the inflight fuel flow readings - they are out.
For total (actual) fuel used I just start from full tanks, fly, refuel to full tanks and adjust metering system (pulse rate) to reflect actual fuel used - seems to work.
Back to Dynon/Red Cubes;
From my reading of the instructions, the return line metering would be automatically deducted from the main line fuel delivery. I assumed that as long as this was a consistent deduction, I need only calibrate the main line. This seems to be incorrect.
So the position now is;
- I have an accurate fuel used reading.
- I need to calibrate the return line flow - what impact will this have on my main line fuel flow callibration?
- To adjust the return line there is no filling of tank/refilling - Other than the filling of a bucket (static) how do I judge the accuracy of the return line calibration & adjust up/down?
