fuel flow parameter red cube
enrico.delsordo
hi , i have installed fuel flow sensor red cube
then fuel flow installed, pin installed as indicated now in the engine info page I can see real time consumption real time flight time.
the red cube is installed before one carburator of my rotax 912
only I can not understand how to set the parameter from the dynon that "I think it's called k".
the system when I fly tells me that I can do with 65 lt 850 kilometer
I think it is the goal and so also for the consumption in reality I think it indicates the half of real consumtion
how can I set the parameters to have the most real values possible?
thanks and good job
You set the number within the setup section: SETUP MENU > HARDWARE CALIBRATION > EMS CALIBRATION > FUEL FLOW CALIBRATION.
FWIW My Redcube uses a factor of 66,200 with my Lycoming O360 which seems to be most accurate. What have others found that works best on their Redcube installation?
Back
