Fuel Flow settings
pacecapt
Pace, Florida
I have a UL 350is and my Dynon HDX does not have a setup for that motor so I just used the "other" engine. My question resolves around fuel flow pulses. The "other" engine setting defaults the feed and return fuel flows at 68000 pulses per second. I have calculated the UL Power pulses based on 48 liters per hour which is less than the default 68k. Question, should both the feed and return line pulses be set to the same value?
