Please can you help:-
We have an EMS-D120 installed in a Polaris with a Rotax 912 engine.
Fuel Flow reading remains on 0 LPH. Another transducer gives the same result. The transducer is fitted in the pipe between the mechanical fuel pump and the splitter going to the two carburettors.
If we disconnect the two hose ends and blow gently into the transducer we get flow of 20-30 LPH. As soon as we connect the piping, flow remains at 0 LPH while the engine is running.
Thank you
Regards
CJ
Thank you
Regards
CJ
