<snip>
The other thing that was mentioned was the +12V they need must be regulated. Any fluctuations in the voltage would result in fluctuations in the readings. Is the +12V from the SV-EMS-220 regulated? That brings up the other question. How much load can I put on the SV-EMS-220 +12V and +5V pins. So far +12V pin will have two fuel flow sensors and possibly the fuel level. The +5V pin will have the MAP sensor plus a Kavlico fuel pressure sensor.
Yes, the 12V output (Pin 15) of the SV-EMS-220 is regulated. It's a reasonable concern of how many sensors can be connected to the SV-EMS-220 12V output, and as of our SkyView System Installation Guide, Rev. K for firmware v3.3*, we offer the following guidance (Page 7-10):
SV-EMS-220 output voltage: 12V
Output current limit: 80 mA
Typical sensors used:
FloScan Fuel Flow Sensor (100403-001): 50mA
EI Fuel Flow Sensor (100403-003): 15mA
UMA Differential Fuel Pressure: 10mA
Rotax Honeywell Oil Pressure Sensor: 20mA
You'll have to determine from the Princeton data sheet if their requirements fit within the output current limit of the SV-EMS-220's 12V output. If not, you'll have to add a regulated 12V supply.
For completeness, here's the corresponding info for the 5V line
SV-EMS-220 output voltage: 5V
Output current limit: 300 mA
Kavlico pressure sensors: 5mA
3rd party trim and flaps position: 5mA
Manifold pressure sensor (100434-000): 10mA
* To be released "soon".
