nitrousinducedcoma
- Joined
- Sep 29, 2009
- Messages
- 3
We have installed fuel probes in our new wings from a company called Sky Sports.This company has since been sold to Aircraft Spruce in which there technical department does not know much about the senders.The manual for the senders says it is a capacitance system.It has no float or other moving parts and works well with a westach dual gauge (part#WS2DA4).We have tried calibrating the tanks both ways (resistance & capacitance).Nothing happens in capacitance mode but we do get what seems to be a good reading in resistance mode for every two gallons we put in.The problem came when flying.When in level flight the level of fuel would be close to accurate but when you change attitude the level of fuel is all over the place.Basically the fuel level bounces around alot.Is this normal for the system.We just want to know if we did the calibration correct and or if theses senders really will work with the Dynon System.Or do we need to install that convertor that you have.Any help with this problem would be helpful.I also sent a couple of pic's of the sender we use.
Regards
Steve
Regards
Steve
