I've just finished installing a FT-60 flow sender in our Rotax 912S Pioneer 300. All works fine in the air with sensible flow rates and Skyviews datalogs show the EMS sees oil pressure and fuel remaining reducing (there is no "fuel used" in the logs).
The Skyview user guide states fuel used (in my case "Ltrs Used") does not get reset until the next startup oil pressure. Mine is being reset to zero the next time I turn on the master switch so the fuel used is lost. The engine has not been turned over since the end of the last flight.
Running V12. Am I missing a configuration setting here?
ta
Steve
Skyview D1000
ta
Steve
Skyview D1000
