Had my fuel pressure reading 9 to 14 psi since I got the plane back from the installer. I have a 180 HP engine with carb
The fuel pressure should be around 5 psi
Dug deep into the set up of sensors and found that the fuel pressure sensor was charted as a 30 psi gauge!
Reset everything to the standard 15 psi sensor and widgit readings and now I'm showing the correct pressures
Hope this helps someone else.
