Garmin 175 coupled to Skyview HDX
LouRubin
I just started experimenting shooting GPS approaches with a Garmin 175. The first thing I noticed the glideslope didnt activate until the FAF about 5 miles from the runway.
Is this normal ? The second approach the final approach course didnt line up with the runway. I also had no glideslope information. Im wondering if the 175 is having issues or its a communication issue with the Skyview?
Marc_J._Zeitlin
Tehachapi, CA 93561
I just started experimenting shooting GPS approaches with a Garmin 175. The first thing I noticed the glideslope didnt activate until the FAF about 5 miles from the runway. Is this normal ?
The VNAV will become active on the GPS175 oon the leg inbound to the FAF. That is normal.
Well, some approaches do not line up with the runway. Look at the RNAV-04 at KMHV, for example. If you don't tell us which approach it was that you're discussing, it's going to be pretty hard for anyone to guess at whether the system is behaving correctly or not.
And since you don't tell us which approach you were on, it's also hard to know if it would/should have had VNAV displayed - was this an LPV, LNAV, LNAV/VNAV, LP+V or LP approach? Not all have vertical guidance... See:
And folks - as has been mentioned numerous times before, the more information on your situation and configuration you can give when asking a question, the more likely it is that someone will be able to help. "This isn't working" isn't a lot to go on...
LouRubin
This approach definitely aligns with the runway. It a LPV approach Runway 1 Sebring Fl. Im thinking its a glitch with the Gnx 175. Is there any information regarding approaches pertaining the Skyview? I didnt see any information in the Pilots manual. Ive read there has been issues with the 175 communicating with the Skyview from several users.
Whats the normal range for the glideslope to activate?
