GPS data
Lucapass
before installing autopilot, the external GPS and the data appeared on Dynon system, after appears the GPS but not the data ( distance, ecc..... ).
In autopilot menu the HSI+ Trk button is inoperative !
I love aviation!
I watched the Dynon training yesterday and, if I recall, the HSI+TRK button is only enabled with the Autopilot set to Expert mode. The default mode is Simple.
So there is no HSI+TRK button. In simplified mode, there are HSI+ALT buttons and TRK+ALT buttons. The former is only selectable if you have a flight plan that is being shown on the HSI that the autopilot can actually follow.
If you mean that you can not select either the TRK or HSI/NAV modes in expert mode, you likely do not have a valid GPS position source.
Lucapass
Sorry, autopilot is already in simple mode, trk+alt is ok ! but hsi+alt is inoperative ?
For the HSI+TRK to be available, you have have valid navigation information on the HSI. Most often, this means having a destination programmed into SkyView's mapping software (but it can also be a connected GPS or NAV radio). Even if you have a "magenta line" on the map, make sure that it's actually displaying the guidance on the HSI. That means course direction and the CDI needle.
Lucapass
look
Lucapass
Is right ?
Lucapass
is right ?
Everything looks fine. You just don't have a destination set on your map so it doesn't know where to fly to. You need to go into the map and give it an airport and then HSI+ALT will show up.
Lucapass
I try but never with external GPS !
Lucapass
Always black map ?! Why I dont' buy a map ?
I think you're in Europe from your transponder code. If that's the case, you can obtain aviation data from PocketFMS data here: http://www.pocketfms.com/dynon/
