GPS for D100
pero
I have a GPS receiver (type GlobalSat BR-355-S4) that i would like to connect to my D100. My GPS is not on the list of "known to work with D100s", but the D100-manual says that an updated list is to be found on the Dynon Wiki-page. This page does not exist anymore as far as I can see. It seems the D100 needs GPRMB, GPRMC, GPGGA and one of either GPBOD or GPAPB.
I cannot find many GPSs that output GPRMB or GPBOD/GPAPB (other than the ones listed as known in the D100 manual).
Anyone know if my GPS will work with the D100, and if so, what info will I be missing due to the missing protocols?
Alternatively, is there an updated list of GPSs that work with the D100?
As it outputs NMEA 0183 & needs a 5 Volt power input, why don't you connect it ? Will not hurt the Dynon . However if you want it to 'drive' an autopilot to follow a GOTO or Fltplan then you're out of luck - that's better served using a Gps with database IMO.
pero
My intention is to use it as a AP source. I don't have moving map anyway on my D100, so i was thinking more in terms of a heading (and altitude) AP. Any idea which functions i'll be missing without the prescribed protocols?
Heading is all you will have with that unit - Alt Hold is a totally independent function & does not need or have any GPS input.
michel@riazuelo.fr
For many years I used a HOLUX GM 210 GPS with my D10A which did not provide GPRMB or GPBOD/GPAPB frames. It is powered by 5V. It allowed me to use the auto-pilot in track mode, which is well suited to VFR.
This GPS no longer works. It is recognized by the D10A, but it no longer does the FIX, so I want to replace it.
Today there are wired GPS systems that are much more efficient than the HOLUX, the Adafruit Ultimate GPS for example (Product ID: 746). Its baud rate is 9600 and 1 Hz, OK for the D10A .. but it is not recognized by the D10A. I checked with a micro controller (ARDUINO) that the frames were compliant, and I even raised the signal level to 5V (TTL).
And no magenta message...
If someone has an idea ....
Michel
Do you have an HS34?
Does the Adafruit output time over the serial stream?
Does it output aviation format, $GPRMC, $GPRMB, $GPGGA, and one of $GPBOD or $GPAPB over the serial stream?
