Jared,
The simple answer is “YES” you should, but I never tried it.
Since the GTX should have the GPS source for ADS-B out, you will need to get a GPS position for the SkyView. The easiest is just find a used GPS-250 for around $75 and install it on port 5 per SkyView’s install manual, and be done with it. You don’t need the GPS-2020 as you already have that in the GTX335. If you don’t want to go that route, below should get you in the right direction.
Connect one of the GTX335 RS232 TX outputs to SkyView serial port 5 RX, and set the GTX335 RS232 TX output to ADS-B+ FMT 2, and the SkyView serial port 5 to GPS-250. The GPS-250 baud rate is 38,400, and the GPS-2020 is like 115,200, so that won’t work as the max baud rate for the GTX335 is 38,400. So you need to set the GTX335 to ADS-B+ FMT 2 which will give you the output baud rate of 38,400.
That should work, in theory anyway.
Good luck, and if it doesn’t, then I have a few GPS-250 laying around, and would let one go for $75 plus shipping. You can email me at
hr2plt@yahoo.com if needed.
Brian
