The RV8 Pilot
www.rv8-hangar.com
- Joined
- Nov 1, 2015
- Messages
- 24
Ok I'm looking at the SV-INTERCOM schematic for two radios 2-4 in the SV-INTERCOM install manual. It shows output from PIN 12 to the switch with two outputs. I have a Tosten grip with 3 wires that will be used for these functions. One common that will run to the SV-INTERCOM PIN 12 and one that will run to SV-COM-425 #1 and one that will run to SV-COM-425 #2. My questions are:
Do I need to shield the wire from my grip to PIN 12 on the SV-INTERCOM?
Do I need to shield the wires from the grip to the SV-COM-425's?
This easiest thing is to not shield them and run directly to the components, shielding will be a lot of extra wire so that I can tie into the shield bundle. Thoughts on this?
