GRT Oil Temp Sensor
badia358
Mebane, NC
I just installed the GRT Oil Temp Sensor (Lycoming O 360). I have a Skyview Classic in my RV-6A. I have not started the engine, but just bring up the Skyview system and it reads -11 degrees. Figured that I would just switch the wires and still reads -11 degrees. Anyone use this GRT Oil Temp Sensor and did it work?
Thank you...
Did you select the right oil temp sender in the sensor pin mapping? The default sensor configuration won't work.
